Dave Hawksford
- Outside the beltway
ah Yes Charlie, I use a Acrylic Black Silicone to bed the Slate and the glass under the slate. I use an epoxy once and found out that when playing the call the class cracked LOL
Don. After remounting the piece I finished the turn and it worked great.
The inside post are what I mount the glass on. Glass is seated a little over 1/8th " to 3/8s as a sounding board. I'll have to get a video up on the sound. I also use a wood hardener to stabilize the wood.
Carol I mount the the waste board with a center screw and hot glue. Seems to work great for my set up."Turning board?" I think you mean a waste block mounted to a faceplate on the lathe and your blank is glued to it? Or what? Or do you have a chuck you are using?
Hot glue is one possibility, but there are more efficient ways. There is a double stick tape turners use to mount a blank but the face of the blank has to be dead flat.
So what are you doing?
