- Springfield, Missouri
So, much of the barn down at the farm has tiny little holes throughout the timbers and siding. There is a lot of siding that I'll be taking off of the lean-to that is covered in small holes, most likely caused by powderpost beetles. Most of those boards are around 6/4 and still in good condition otherwise.
Anyone used any of the pesticide products, such as Tim-bor or Boracare to treat lumber?
I realize that these both soak into the wood, so I'm more concerned about finishes that may be applied later. Both will leave a salt like residue, but if I removed the top layers using a planner I'm hoping to use some for furniture, obviously not for cutting boards and such. I think the bora-care is a glycol base that helps it soak in further, so leaning more towards the Tim-bor product, though both do need to soak in deeply to do the job.
I know it probably can be killed dried for a while to kill them as well, but I doubt I'll have a kiln built for it anytime soon and don't want to transport the wood anywhere unless it is treated.
