rebuliding delta 40-440 scroll saw
Gary miller
Tulsa Oklahoma
hi folks
thanks for letting me join.
i inherited this old saw from my farther in law. so i thought i would get it running in his honor. he was a very good wood worker. but it is missing a motor and rear rear pulley. the motor is not a problem. i have a nice 1/2 hr. 1750 rpms. i think that should work. i want to install step pulleys so it will have adjustable speeds. any idea what the sizes should be? and can you use off the shelf pulleys or are they a special size ?
Jim DeLaney
Austintown, Ohio
Pretty sure that saw has a half inch diameter shaft, so a 'regular' hardware store pulley ought to work. Not sure the four-step is necessary, though. A 1:2 drive will give you about 875 strokes per minute.
I'm thinking your bigger challenge will be finding the short, pin-end blades for it.
And BTW, welcome aboard.
Post some pictures of that saw if you can. We're also looking forward to seeing pix of some of the work you do with that saw once you get it up and running.
Charles Lent
Central North Carolina
I've found that www.thewoodenteddybear.com is the best source for scroll saw blades both pinned end and un-pinned. I have been buying only from them for about 8 years now. Their prices are good and they ship quickly. I prefer the Flying Dutchman brand blades since their quality seems to be better than other brands. I was having a lot of trouble with Olson blades because the blade teeth were not evenly offset, so the blades wanted to cut with an offset. I switched to Flying Dutchman blades (manufactured by Nigua) and no longer have this problem. I believe that they are made in Switzerland. Olson blades are made in Bethel, CT. Olson PGT (precision ground teeth) blades are quite good, but I had a lot of problems with their regular blades.
You will also find that most people learning and using scroll saws can be found on the www.scrollsawvillage.com forum. Many people who scroll saw are not full woodworkers with woodworking shops like us, but some are incredibly talented in scroll sawing, probably because that is the only woodworking that they do.
I have been scrolling for about 50 years now, beginning with a pin end type saw, but now I'm on my 3rd pin less blade saw, a DeWalt 788 type 1 and I may be upgrading again soon. Scroll sawing technology took a giant step forward about 25 years ago when the saw designs changed from pulling the blade up via a spring to the design that now mechanically pulls the blade up as well as down. Changing the design to use blade grips that can hold pin less blades was another significant design change that occurred at about the same time. We can now use much smaller blade sizes and drill much smaller blade feed through holes for making inside cuts. With this new generation of saw, the blade can be tensioned much higher, resulting in much straighter and cleaner cuts, and the blades, even the 1/0-2/0 sizes, usually wear out long before they break. The old spring return saws frequently broke even the larger blades when the user caused the blade to bind in the work. The spring couldn't pull the blade up because of the binding, but the machinery below pushed it up anyway, buckling and then breaking, the blade.
It's fun to restore old woodworking tools, but sometimes the technology that created them is now quite obsolete. Go ahead and finish your restoration of that saw and get some blades that fit it, but don't give up on scroll sawing after using it for a while, at least not until you try out one of the newer technology scroll saws. They aren't the same at all. There is almost no comparison between what you have and one of this new generation of scroll saw.
I've been making reindeer using my scroll saw every year for the past 16 years. My smallest is shown in the attached photos. I make 4 sizes and this one is the smallest. I've now made well over 5,000 reindeer in the past 16 years and give them away as Christmas gifts, but I make many other things as well. The cross is another. I cut it out using my scroll saw, but then used an air powered dentist drill with 1/16" shank bits to carve the leaves and vines.
Gary miller
Tulsa Oklahoma
Sorry, I haven’t got back to the saw project. Does anyone know the ratio of the great box? I can not find it written anywhere. Or how to turn RPMs into SPMs? Anyway, thanks for the posts and welcomes! I am very glad to be here.
Jim DeLaney
Austintown, Ohio
The 'gearbox" on the saw is just a simple crankshaft. One turn is one full up/down stroke.
BTW, there should be an arrow adjacent the pulley showing the direction of rotation. Make sure it's turning the right way. Turning it backwards will sling oil out of the crankcase.
