Mark Rios
- Central CA
Frank P. mentioned in a post in the Funding thread that some more content was needed including tool evaluations so here is a little review that I've been thinking about.
The Freud LU80R010 10" x 80-Tooth HiATB Coated Industrial Ultra Finish Saw Blade. (For clarification, the name on the blade itself is: "Ultimate Plywood and Laminate")
I was turned on to this blade late last Spring by someone over at SMC when I was asking about a plywood blade in a discussion about blades in general. He said that I should expect the sweetest of sweet cuts from it and he wasn't exaggerating.
I bought one from Amazon and used it the day that I got it on some old, ratty looking but clean 3/4" CDX. When I took it out of it's cover it even looked sharp. VERY sharp, pointy teeth on this blade. If you get one, be careful handling it....very pointy-pointy. The cut was great, both on the top and on the bottom of the plywood WITHOUT using a ZCI on my old Ridgid Contractor saw. I figured that I should try it out on some "good" ply so I put some 3'4" oak ply up on the TS with the same standard insert. Again, extremely crisp, sharp edges on the top and bottom. I went right in and ordered a second one.
Forward to the past couple of weeks.......
I recently finished cutting out all of the carcass pieces for a set of 14 cabinets for a kitchen remodel that I'm currently involved in. This is for a regular, paying customer and not for a rental or sale by the realtor that I work for so this is to be a nice set of cabinets (I hope
). I'm using birch for all of the interior carcass material and maple ply for the exposed sides. The doors and drawers are inset panel so I used 1/4" (5.2mm ?) mdf core maple ply for the panels. Drawer material is 1/2" BB. This is the second set of cabinets on this blade, now on my Unisaw, and it is still cutting crisply and cleanly. It doesn't cut very quickly on other, solid materials but it is an 80 tooth after all. It also doesn't have a good feel when cutting through oak or maple solid wood but it has, appropriately, a very good, natural cutting feel when going through plywood. I happen to be a person who prefers a dedicated blade appropriate to the type of cutting at hand and this blade is by far the nicest blade that I have used. BTW, the cutting that I am referring to and judge cuts by is crosscutting plywood, as I feel that you can get a great rip cut in plywood with most any good quality blade, and some not so good ones.
The blade costs upwards of $100, I paid $92 or $93 for mine, so it's not cheap. But I feel it's worth it to not have to worry about my crosscut plywood having furry edges and trying to edgeband to them. The teeth stay sharp and produce excellent edges. It does all that I can ask for in a plywood blade.
Thanks for reading.
Thanks for reading.
