Robert Horky
Needed to turn this mostly unusable space into something functional. Not a glamorous project but well needed.
I need to clean up the wiring and fasten it down and should be good.
Construction: BB plywood, 3/4 and 1/2, rabbet/dado joints.
Finish: shellac (to minimize sanding), several coats of General Finishes water based poly.
Turns out, when I went to slip the cabinet in the stand, the stand was not quite square. More slop in those square carriage bolt holes than I realized. So, I loosened all the connections and clamped the frame to the cabinet, then tightened them all back up. Worked like a charm.
Thanks for looking.
Thanks for looking.
