- Yorktown, Virginia
Don't know how much experience you have with using CA on bowls, but even the medium strength stuff will soak into the surrounding wood for a good distance from the crack and create a blemish around the crack on the finished product. I try to create a bottom backer and a top dam using blue painters tape to protect the area around the crack. If the bowl is thick when you fill the crack you can easily turn away the excess and there won't be a problem. Precautions help if you are near finished wall thickness.
I suspect you may find similar cracks in any of the blanks from this batch. As was mentioned upthread, it's very common for full blanks to crack when drying. It's a lot easier to control (limit) the cracking on a rough-turned green bowl than it is to keep it in check (no pun intended) on an unturned blank.
