- Springfield, Missouri
I was pricing mini-splits for the shop and noticed some of the manufactures are starting to offer air handler and furnace A coil units. Looks like these could be a diy install for the person needing to replace their old furnace/ac.
We have a forced air geothermal in the house that was installed in the 90's. It's not all that efficient anymore. It could probably use a good cleaning, but it's not something my wife would want to maintain if I was to kick the bucket anyway.
Pioneer® 56,000 BTU 17 SEER2 Ducted Central Split Inverter+ Air Conditioner Heat Pump System, 2nd Generation
Boost home comfort with our high-efficiency Split Heat Pump System. Side-discharge, downflow capable air handler & direct communication for optimal performance!
www.pioneerminisplit.com
Pioneer® 42,000~60,000 BTU Furnace-Connect Multi-Position Cased AC Heat Pump A-Coil
Maximize home comfort with Pioneer's Cased A-Coil, adaptable for 42K-60K BTU systems. Perfect match for existing furnaces & Pioneer heat pump condensers.
