Record Crate Version 2
Brent Dowell
Well, a buddy who dj's with 45's asked if I could make him some record crates.
Sure thing, the only issue is that if I prebuild them, they are pretty good sized, and are expensive to ship. So I redesigned the crates to a knock down design that uses 10-24 machine screws and cross dowel bolts to hold them together.
It was a first for me as I designed it in sketchup, then imported the vectors into Vcarve to design and cut the pieces.
I also discovered that using a 1/8" up/down cut bit really helped reduce the amount of chipout on the crappy Borg ply I'm using. Yes, I could make these out of better wood, but the crappy ply is part of the charm, lol.
Had to make a number of prototypes to get the fit just right. These slide together easily, with enough friction to make them snug. I leave the tabs a little proud so I a quick sanding should make everything look nice.
So now I can make the boxes and hopefully just slip them in a flat rate box and send them off.
Now I need to work on the crate design for the LP's
Here's the design in sketchup.
I simplified the SU files and then imported them into vcarve.
The final prototype/ first production box.
Of course part of the project is to laser a logo on the from of the box.
Now that you have the pattern nailed down, you can just sub the cutting out to a big CNC shop and have them drop ship the product. I'm thinking there are at least dozens of people who would buy these :D
Hmmm, What does a business plan for 'dozens' look like, lol.
Hmmm, I wonder if I could sell enough to buy a bigger cnc?
I like the knock-down design, Brent. :thumb:
Looks good! :thumb:
I need to come up with a design to store all 20,000 of my mp3s in. ;)
That's gonna be a little bitty box, lol. :D
You just made me go check the size of my digital music collection.
65 gigabytes so far. But I have another several gig I haven't moved into my library yet.
LP Sized crate design prototype. All I have to do is make the tenons on the sides a touch thicker, but it works well.
I'm really happy with the cheap new laser on my ox CNC. Used lightburn to generate the gcode file and uploaded it to cncjs.
