May 28
My buddy — you know, the guy who actually knows what he is doing — couldn’t make it last night. So it was just me and my two sons, and one other guy who popped by for a while.
So there was not a huge amount of progress, but still made some steps forward.
We’re now at the trimming out stage. So I read the Ted Moores book section about fitting the inwales and worked on getting one fitted.
First, I took a few posed shots, just to show how far we were. Here it is inside just after we arrived.
Then we trimmed off all the extra fibreglass and moved it out for more space and better light
First, we measured and marked the centre of the boat — centre from front to back I mean, not the side-to-side centre. Then we measured and marked the centre of one of the inhales and clamped it in place along the inside.
You can’t quite see it in the photo, but the ends of the inhale are set on the OTHER side of the stem for measuring. The stems still stick up a bit, so they help holding the inwale.
We clamped it as far as we could until it would not flex into position any more. Then we measured along the side of the CANOE to see how far it was (about 26” in my case), and made a mark on the inwale. Then measured forward along the inwale from that mark 26”. That SHOULD be the point at which we want to cut the inwale so that it will fit in place, snug up to the inside of the stem.
Yeah, this is hard to explain, I should have taken photos of each step.
This is repeated for the other end. Then the inwale is removed from the canoe and brought to the bench. At this point I cut the inwale to length. I then also cut a taper. The inwale needs to taper down so that it is half the width of the inside of the stem. The OTHER inwale will occupy the other half. The stem is about 5/8” wide, so I needed to taper the inwale down to 5/16”. One thing the book does NOT tell me is how LONG the taper should be. In a sense it probably doesn’t matter too much, as we will be filling that in with a deck.
Then we fitted the inwale back into position and it fit perfectly!!!
Yes I’m lying.
I needed to dismount it twice more until I was happy. But better it is too long than too short! Here it is clamped into position.
And a close-up on the one end. You can see how we also need to trim down the cedar to give us a fair curve. That is boat-build-speak for “we need to trim the cedar down to follow the line of the inwale. And yes, there is more to the term “fair curve” than that, but it’s close enough for this situation!
Next time we should be gluing the one inwale in place with epoxy — epoxy is forever, so we want to be sure before we do that! And after that the other inwale.
