Bartee, I have to figure out a final height for my saw as well, I want to be able to use the SawStop for outfeed for the two bandsaws if needed.
I think the saw will be here on the 12th, if the customs guys have had a good enough look at it
I've been clearing the decks, getting ready..........
Looking North
Looking South
There is so much space in the middle of the Dungeon I felt like getting out my hockey stick and shooting some pucks around
Just a few more days, I think I have it all figured out, let me explain the steps, I have mapped out.
The charter that is delivering the saw knows they are delivering to a residence, no loading dock, so they have a lift gate, and they have promised to have a pallet jack as well to move the saw, on the pallet, into the parking area of my building.
My Dungeon is the back half of the underground section of the building, there is a second hatch for the front section of the underground, I call the section the "Annex", over that hatch, there is a hook to hang a hoist on as well, up in the ceiling.
Here is a pic of my jointer when I unloaded it from the trailer.
I'll get the saw dropped there, then we will unpack it, I imagine it will look something like this..........
I borrowed one of Bartee's pics
When we get it all unpacked, we will tip it up and put some spacers under it, then slide the cargo straps I've got, they are rated for 1.2 tonnes each, so they should be fine for the saw. The saw will be lifted, and then put on a large cart we have, that is rated to 300 Kg (660 lbs). I'll then put the chain hoist on the hook over the Dungeon hatch. Next I'll install my two small bridges in the hatch, I've made them from 2x6s with the right spacers so they sit level with the floor, each bridge is two 2x6s, one flat, on top, and one screwed and glued to the underside to make a "T", for strength. The cart with the saw on it will be rolled onto the bridge, and then the hoist will lift the saw from the cart, the cart will be removed, as well as the bridges, and then the saw will be lowered into the Dungeon.
I hope to have Alex and Jake here to help me, one guy down in the Dungeon to help guide the saw on the trip down, and two guys up top one to guide, and one to work the hoist.
The two cargo straps will go around under the saw, and I'm thinking I'll also use two other straps horizontally on the saw to hold the cargo straps in place, so they cannot shift.
I've worked this scenario out in my mind over and over for the last two months, well nearly three months, and I think I've got it all covered......... I hope I have
What do you think.............?
