In Memoriam
- Coolidge, AZ
Well, today I got started rehabbing the old Timberline saw. I got the arbor back a couple of weeks ago, but life intervened. New bears and repaired shaft. Looks and spins sweet! So today, I began cleaning up the parts. The 'box' is aluminum and the outside had some sort of paint on it. Under the corrosion it looked galvanized, or a mottled machine grey. You can see the contrast after I drilled out the pop rivets and removed the name and angle number plates.
I cleaned it all off. It got a Simple Green bath and sanding. I think I want to paint it again. Main reason is I could not get a nice cleaned around the rivets that hold the base ring on or the back strap braces the provide the opening for the motor belt. You can see the rivets near the bottom pf the picture. Painting it would make it look nice and the cost is only one rattle can of something. But what? Do I need a special paint. I was thinking hammered machine grey.
FWIW, this is not a antique restoration. This is clean it up, make it look nice and then use it! Not all the original parts were there to begin with, so no point trying to go there. And I plan some mods to make it a super slick, multi-featured accurate tablesaw to use building the house. Then, who knows. I don't yet.
Your thoughts about and for paint?
