So I am working on the wiring diagram for the CNC build and I download a file that says "Read Me FirstUIUIUI" and here is what it said.
"You should be very careful when you operate a machine,otherwise it will be dangerous!
Most beginners encounter most error is that run the G code when you have not mastered each attribute of the machine!
This will cause the engraving machine spindle motor strike the engraving machine bracket.
So suggest you to install the limit switches,emergency stop switches first! If you didn't install these protective switches,
In case of emergency,except to press the emergency stop to reset (sometimes no time to press), turn off the power supply.
The most convenient way is:Unplug the USB cable! Unplug the USB cable, the machine will automatically turn off! "
Thats good advice..... I Think.....
