Tiki Bar - Done!
Brent Dowell
Well, Sharon said she wanted a tiki bar a while ago. I have no problems with the idea, so decided why not start on it. Fortunately, I have most of the materials around.
This isn't going to be any kind of fine woodworking, but really just more of some rough outside furniture, not outside outside, but under a roof outside.
I could have gone with something simple and rectangular, but decided that I'd do a curved one, just for grins. It'll be about 7' wide, by 41" tall. Figure I'll get 5 barstools for it, 1 for the bartender and 4 for the guests.
Heres the basic design. It's just a rough design, I'll have more timber on the inside for support, but you get the idea.
I ordered a bamboo panel off of amazon that I'll wrap around the front of it. I'll put some rgb leds along the top and bottom that will shine through the bamboo paneling. I'll probably put some on the inside a bit as well.
Today I cut out all of the plywood pieces. I explored a bunch of different ideas on how to draw/cut out the parts and settled on making this temporary jig with my panel cutting setup.
Basically screwed a piece of ply to the table I use that goes perpendicular to the board and mounted my little milwaukee battery powered router to one end. The other end I would put at specific radius to cut out the parts. Worked great!
And I put all my tools and supplies away and did not end up with any extra screws in a miscellaneous screw bucket.
Got a start on it today. My only fear is if you lean on that very front part, it wants to lean over forward a little bit. I may add an additional bottom curve that sticks out on the bottom to alleviate that issue.
Going to take a break for a while and give it a think, but so far it's exceeding sharons expectations.
I do think some sandbags on the bottom shelf would provide enough stability. I made the overhang a bit smaller than I really wanted cause I could see that this issue could crop up. I bet with a few bags of play sand on the bottom shelf it will stay steady.
Sharon is in charge of buying the barstools. I do have some pretty substantial bamboo I might try and make one out of, but I not sure how sturdy I could really make them. I'd be more comfortable having something pre-engineered and pre-made.
add a curved brass rail
Might be a little expensive for what I'm trying to get away with. but I wonder if I could bend up some kind of foot rail out of wood?
Sand bags was my first thought, but what about maybe some 1/4” flat bar stock, even stainless, screwed to the base extending out to match the overhang?
Might keep it lighter to move.
I made a tiki bar a while ago, I also used the bamboo fencing for the front....no led light, I put a back in, and used a flourescent bulb with colored cover to light it up. not that fancy, but it got plenty of use and on wheels so it was moved easy enough
Thats so cool! I hope mine turns out half as good. I might need some of that 'roofing'
this was the first one I made, I dont recall exactly but it was built in a few hours and needed for a block p;arty...the girl behind the counter was a good friend of my son and asked if I could make it and use, we got it back, but i took it apart and used the wood for adirondack chairs, kept the sign. simple as can be, but everyone loved it at the block party.
whenever my son has his new deck installed we are going to build a huge tiki bar....with a sink, running water, and an clear glass door fridge for chilled beverages. I believe we will go with the led lighting also. only the person tending bar needs a couple of decent lights above so they can see what they are doing and mixing.
